Hello all, so I have spent probably a good 8 hours googling and testing and trying and I am out of ideas here on what else to do.
So my computer won't give me a video display on original boot for me to get to bios... So I brought it down to my motherboard, CPU, RAM, PSU
Motherboard: MSI Z170A Tomahawk AC LGA 1151
CPU: Intel Core i7-7700k Kaby Lake Quad-Core 4.2 GHz LGA 1151
Ram: Corsair Vengeance LPX 16 GB (2x8gb) 288-pin DDR4 SDRAM DDR4 2400
PSU: Corsair CX750M 750W ATX Power supply
So I have gone through the Toms Hardware List for not getting a video output. I am using the DVI Display port off of the motherboard, I had tried also to use my graphics card prior to taking it apart, but broke it down to bare basics here. I have the trouble speaker plugged in and my motherboard has EZ Debug lights. I have tried both sticks of ram in every slot and configuration, my motherboard is setup so that slot 2 and 4 is for dual channel but tried both sticks singular, I have ran through multiple online articles, other peoples problems, whether things were seated right, took a look at my CPU and the pins and nothing seemed out of the ordinary. So I took the ram out and got 3 beeps and the EZ Debug light came on for the ram, typical because it had no ram in it I wanted to see if it atleast worked. I plug it all in and no debug lights, every LED and Fan comes on and spins, no beeps, no sounds, nothing but I can't get a video display. I am really confused on what else I should be testing or overlooked. I figured I would break it down and run through Toms Hardware check list again, but can't get anything to happen still... so I am out of ideas. Any help would be appreciated,
thank you everyone,
Colton
https://linustechtips.com/topic/788865-video-problem/
Try to go into the Bios and turn the display output as the onboard
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/788865-video-problem/#findComment-9938819
11 minutes ago, Coltonwmcc said:
I can't get a video output on anything, would I just have to go through the manual and try and guess which keys to hit to try and navigate the bios and get to that?
Reset the CMOS - consult your mobo manual for this. If you can't find anything about it, look for a small hearing aid like battery, unplug your PSU and take it out for 30 seconds. Put it back in and try to boot again. If you used a GPU on your first boot, it may have disabled the iGPU in the BIOS
https://linustechtips.com/topic/788865-video-problem/#findComment-9938906
