changing water
Go to solution Solved by Damascus,
I've heard that 6 months is a good time period for this kind of stuff.
Just now, Damascus said:
Is your loop a soft tube clear setup?
What is your coolant?
Is there green gunk in the loop (if it is clear)
Soft clear tube with this https://www.komplett.se/product/825146#
Watches and computers
https://linustechtips.com/topic/788610-changing-water/#findComment-9935080
When my loop is using coolant that has Biocidals then I have let my loop run for two years without issue.  EK's old formula was great from that perspective.  But as soon as you see any discoloration in your tubes then you need to clean them immediately.
https://linustechtips.com/topic/788610-changing-water/#findComment-9939266
