Loop config help
Go to solution Solved by WunderWuffle,
Loop order doesn't matter, so just route your tubing so your system looks nice. The only think that matters is that your res goes before your pump.
Hey
Should I config the loop as:
Res -> Pump -> Rad1 -> Rad2 -> Waterblock(s) -> Res
                                  or
Res -> Pump -> Rad1 -> Waterblock -> Rad2 -> Waterblock -> Res
Dont particularly care about spacing as this is not an issue.  I do care about performance though so which is better for performance loops?  Or does it not even matter?
Ta
CPU: i7 4770K 4.2Ghz, Mobo: Asrock Fatal1ty Z97x Killer, GFX: EVGA GTX 780 Ti SC ACX (x2 SLI), RAM: G.Skill 1600Mhz CAS 9 16GB, DSK Intel 530 120GB OS, Crucial M500 120GB, WD 1TB Blue, WD 1TB Green, PSU: Corsair AX1200i, Case: Obsidian 750D.
SERVER HP ProLiant Microserver N54L, FreeNAS: ZFS, 8TB (4x 2TB WD Red), RAID Z2, 16GB ECC RAM, 1Gb/s Link Aggregated:  Running as NAS, Plex, & ownCloud
https://linustechtips.com/topic/78806-loop-config-help/
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/78806-loop-config-help/#findComment-1081938
mad
thanks
https://linustechtips.com/topic/78806-loop-config-help/#findComment-1081957
