I've been testing some OC on my 1600 and managed a stable 3.8GHz @ 1.375V throu BIOS. Thing is, when I try to OC with Ryzen Master, whatever value i set as CPU voltage, it won't change. I also tried setting vcore to auto in BIOS, but still nothing. I can set higher voltages within BIOS, but I don't need the CPU to run 24/7 at 1.4+V.
Could someone explain why I can't change vcore with Ryzen Master?
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
https://linustechtips.com/topic/787524-simple-ryzen-master-question/
Just now, Mooshi said:
Software overclocking will always be janky for cpus, always do this through the bios to avoid headache.
Yeah I was using Ryzen Master only for a quick jump to 3.9-4.0GHz with increased voltages, I didn't want to run 1.4 or more V constantly. Too bad it doesn't work, I'll stick with my current OC
Yeah, I wish they sorted it out too. The golden 4ghz is just out of my reach for 24/7 and I'm not willing to go to 1.4+ haha.
1.45V is the safe max daily OC. I run 4 GHz at 1.41 on my 1700. People on this forum are running 1.5V+
