Help with mobo
Go to solution Solved by Billy_Mays,
It's fine
yeah it works fine.
however, that SSD ain't great.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/786793-help-with-mobo/#findComment-9913719
Just now, AndreLebrao said:
the UV400 is really bad.
check the SSD tier list in my sig
anything tier 2 or 1 should beat it in most cases except for sequential reads and writes. (since it's NVME)
Laptop:
https://linustechtips.com/topic/786793-help-with-mobo/#findComment-9913864
