I know the questions might sound wierd, also sorry if I'm not in the right place at the forum.
But my GPU is starting to get dust and I am soon going to clean it, when we move, but I had a question my GPU hits the 65-67 degress in stresstests and I wanted to know more about the thermal grease and how it works.
1. Should I worry over the grease on a 1070 ROG STRIX, after 8-9 months?
2. What temperatures can the grease hold to?
3. How often should I maybe reapply new grease?
4. My old 680 hitted over 70 degress in a lot of games after cleaning was around 3 years old, is that really enough time for the grease to dry out? it hitted around 90 degress in Dead by Daylight on lowest settings.
Reason I ask is because I'd be sad if I had to take my card apart after 2 years of using it. :)
https://linustechtips.com/topic/786562-question-about-dust-thermalpaste/
