I need help choosing a case for a build that I will be doing in the summer. I'm not doing anything crazy, no water cooling at all. I'll probably only have a single GPU as well.
If you have any other case suggestions drop it below
So the cases that I'm deciding on are:
Phanteks p400s Tempered Glass White
Bequiet Pure Base 600 Tempered Glass Orange
Corsair Carbide 400c White
Corsair Air 240 White or the Air 540 white
Nzxt H440 / S340 Elite
Thermaltake Core P5 Open Air Case
https://linustechtips.com/topic/786249-help-me-choose-a-case/
check out the new Phanteks Shift!  that thing is awesome (ITX only).
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/786249-help-me-choose-a-case/#findComment-9906926
2 minutes ago, Jorbee said:
yeah i heard about it, i like how its like tall and stuff but im a first time system builder and i want something easier to work with
The Air series is ridiculously easy to work with.The P5 is kinda hard to maintain(dust) and the rest are just aberage but really good looking cases
My life
https://linustechtips.com/topic/786249-help-me-choose-a-case/#findComment-9906965
1
At this point im considering either the Air 240 or the Phanteks p400 tempered glass one. Where i live they are 15$ apart. Which one would you prefer
https://linustechtips.com/topic/786249-help-me-choose-a-case/#findComment-9907052
Air 240 but you know it's personal prefrence
My life
https://linustechtips.com/topic/786249-help-me-choose-a-case/#findComment-9907133
