This PSU is in my brother's prebuilt from Cyber PowerPC.
Probably not a high-quality unit, and it's not really on any tier lists.
Xtreme Gear 800W
XG-H800
So where do you think it falls? Tier 6, Tier 7?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/785716-psu-quality-check/
Xtreme Gear 800W
XG-H800
Tier 6
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/785716-psu-quality-check/#findComment-9901400
There is no review of it whatsoever but there is, you guessed it, complaints
https://www.cyberpowerpc.com/forum/xtremegear-800-watt-power-supply-another-failure_topic19111.html
At least it has 80+ Bronze sticker on it lol. Well but at the same time a Thermaltake TR2 is also an 80+ Bronze. Efficiency means nothing to quality remeber.
Tier 6 and 7 are both shit already so it doesn't matter if it failed to make the last tier but ends up 1 tier above. Defo not a 4, maybe a 5 but those are all speculations.
https://linustechtips.com/topic/785716-psu-quality-check/#findComment-9901406
@deXxterlab97 @Ordinarily_Greater @lee32uk
I just checked voltages in the BIOS, and while under barely any load (because i was in BIOS, Duh) I was actually both surprised and dissapointed
3.3V Rail = 3.29 - 3.31
- Actually incredible voltage regulation for this rail
5V Rail = 5.16
- Not very incredible voltage regulation for this one. Actually incredibly horrible
12V Rail = 12.08 - 12.1
- 100mv off is pretty bad, but nothing bad enough to cause instant death.
obviously, this isn't under any load, and I'm pretty sure that regulation might get worse under more heavy workloads, but AFAIK, it's at least passable.
Laptop:
https://linustechtips.com/topic/785716-psu-quality-check/#findComment-9906633
