Hi all,
I wanted to code something so i challenged myself to writing a program in C# based on the Countdown Program Math
however coding with Flu is not the best idea! :(
1. Creating random numbers based on user input in done [user chooses Highest Number any number can be] & user chooses how many numbers their will be]
2. What i'm struggling with is the best way to Create As random as possible equation for the user to work out. i created a quick mock-up to test a theory which did not work
3. i want to pick a random number from the array + random operator then put the formula & Answer into different strings to hide from user.
For anyone that has not seen Countdown
Only Rule i believe is:
1. Only each number once
namespace Math_Trainner
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        List<int> Number_list = new List<int>();
        List<string> MathOperation = new List<string>(new string[] { "+", "/", "-","*" });
        List<string> Answer = new List<string>();
        int loop = 0;
        int HighestNumber = 0;
        int NumberAmount = 0;
        string MathAnswer;
        private void RandomNumber()
            int HighestNumber = Int32.Parse(Max_Number.Text);
            int NumberAmount = Int32.Parse(Max_Ints.Text);
            Random rnd = new Random();
            while (loop < NumberAmount)
                int Number = rnd.Next(0, HighestNumber);
                Number_list.Add(Number);
                Listbox.Items.Add(Number);
                loop++;
        private void CreateMaths()
        private void Start_Click(object sender, EventArgs e)
            RandomNumber();
            CreateMaths();
https://linustechtips.com/topic/785690-c-challenge-help/
3 hours ago, smogsy said:
Hi all,
        public Form1()
        int loop = 0;
        string MathAnswer;
                loop++;
            RandomNumber();
            CreateMaths();
Ooooookey dokey, you got my attention.
It is an interesting idea, a difficult one, but quite cool.
The way I could see the algorithm work is:
1. Choose random number of brackets (0-3)
2. For each bracket choose number of elements that it has to contain (if 3 brackets chosen then each of them must contain 2 elements, if 2 chosen then it can be 2-2, 2-3, 2-4 or 3-3 and if one chosen then it could be 2, 3, 4 or 5)
3. Choose elements for each bracket
4. Choose positions of elements in the brackets
5. Choose placement of elements in the equation (brackets and numbers)
6. Choose operators between elements (This is where it looses its shit kind of)
So:
Random numbers:
25 50 75 100 3 6
Step 1:
Number of brackets: 1
Step 2:
Number of elements in the bracket: 2
Step 3:
Numbers in the bracket: 100, 6
Step 4:
Position of elements in the bracket (either 100, 6 or 6, 100): 100, 6
Step 5:
Positions of all elements:
0|	(100 ? 6)
1|	3
2|	75
3|	50
4|	25
Step 6:
Operations between numbers:
(100 + 6) * 3 * 75 - 50 / 25
The biggest problem is what to do if some of the numbers are not divisible by each other and how to not get an answer like 943,928837361009 or something like this (unless you are telling the user to round the value in which case it's no longer a problem). What I would also recommend is letting user choose a random seed, so program would generate the same equation every time.
My answer may be total bullshit since I didn't test it or anything like that.
It's a fun project and if you actually do it they definitely post it here, I would love to play it ;)
Try, fail, learn, repeat...
https://linustechtips.com/topic/785690-c-challenge-help/#findComment-9902199
I started coding my version and quickly realized its not as simple as I thought, it will take me some time... The only hard part (in my eyes) is checking that the numbers can be divided by one another. Give me a couple of hours (I need to eat) and I'll see what I can do :) Awesome challenge though
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/785690-c-challenge-help/#findComment-9902251
If (Number1 % Number2 == 0) ?
https://linustechtips.com/topic/785690-c-challenge-help/#findComment-9902414
I mean how to store the valid divisions, parse them , and perform the arithmetics following the correct precedence and valid divisions
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/785690-c-challenge-help/#findComment-9902423
i missed a huge flaw. in coutdown you must select big little or small numbers and how many
so an update the GUI
The code is optimized be aware. Just to show you where i'm at. Probably get the random numbers into one function when i have not got the flu!
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
        public Form1()
        int loop = 0;
        private void RandomNumber_low()
            loop = 0;
            int Low_Num = Int32.Parse(Low_Number.Text);
            while (loop < Low_Num)
                int Number = rnd.Next(0, 10);
                loop++;
        private void RandomNumber_Medium()
            loop = 0;
            int Medium_Num = Int32.Parse(Medium_Number.Text);
            while (loop < Medium_Num)
                int Number = rnd.Next(10, 100);
                loop++;
        private void RandomNumber_High()
            loop = 0;
            int High_Num = Int32.Parse(High_Number.Text);
            while (loop < High_Num)
                int Number = rnd.Next(100, 900);
                loop++;
        private void Low_number_Button_Click(object sender, EventArgs e)
            RandomNumber_low();
        private void Medium_Number_Button_Click(object sender, EventArgs e)
            RandomNumber_Medium();
        private void High_Number_button_Click(object sender, EventArgs e)
            RandomNumber_High();
https://linustechtips.com/topic/785690-c-challenge-help/#findComment-9904215
