I've been noticing that my printer seems to have a lot of trouble with infill support. If it is making a line, the line seems to break up a bit in random areas. Oddly enough, everything on the outside is perfect, only the inside is where trouble starts.
Settings:
Monoprice Maker Select V2
100% Flow
200c Temp
50c Bed
40% infill
40 mm/s print speed (usually its 60 but I was seeing if it mattered, doesnt seem to)
120 mm/s travel speed
.8mm wall thickness
.1mm Layer height
I use Cura 2.4/2.5. I don't know if my settings are normal or not. I have had completed prints but have never opened one to see if the support worked.
https://linustechtips.com/topic/784979-3d-printing-infill-issues/
