Hi everyone,
I need to get a new Ethernet cable but I'm not sure which one. There are all different names like cat5, cat6 and cat6e. My Ethernet is 40up 2(maybe 3:4) down. Which sort cable do I need to get? It needs to be 20meter long.
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/784749-which-ethernet-cable/
cat5e is all you ever need.
best to buy a large roll make the ends up yourself.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
https://linustechtips.com/topic/784749-which-ethernet-cable/#findComment-9890794
Cat5 will work for you but to be future proof I would suggest Cat5e.
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/784749-which-ethernet-cable/#findComment-9890799
6 minutes ago, Walt said:
Hi everyone,
Thanks!
Just buy the BLUE one.
Seriously though ... as long as its at least Cat5E or higher (like Cat 6) it wont matter.
They are all rated to 100m max distance, the only difference is if they are 1 Gigabit (cat5e, cat6) or 10Gigabit certified (Cat 6e).
https://linustechtips.com/topic/784749-which-ethernet-cable/#findComment-9890802
16 minutes ago, Walt said:
Hi everyone,
Thanks!
cat5e or cat6 is all you need
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/784749-which-ethernet-cable/#findComment-9890818
Just get Cat5e
Get a cable long enough to run between the devices you want to connect with some slack
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/784749-which-ethernet-cable/#findComment-9890969
