Just looking for any and all feedback. Possible changes/should have instead. To keep it simple - this is a build for a friend to run VR (HTC VIVE) and Stream movies from Kodi / Plex. Current specs are as followed. (nothing purchased yet)
Case: Cooler Master HAF 912
CPU Cooler: Corsair Hydro Series H55
Fans: 4xNoctua NF-F12
GPU: EVGA GeForce GTX 1060 SC 6GB
HDD: 2x1TB WD Blue
Motherboard: ASUS H170 Pro Gaming
Optical Drive: ASUS DRW-24B1ST
OS: Windows 10 Home 64-Bit
Processor: Intel Core i5-7500 Kaby Lake Quad-Core 3.4GHz
PSU: Thermaltake Toughpower Grand RGB 750w
RAM: 2x8GB G.SKILL Ripjaws V Series
SSD: 1x120GB Kingston SSDNow V400 SK Hynix SL308.
I welcome all suggestions, just please don't say "because it's better".
https://linustechtips.com/topic/784582-possible-vr-machine-build/
I'd say Ryzen 1500X and a 1070 if he can afford it. They Ryzen 1500X is a 4c/8t CPU that's cheaper than many i5s, or you could get a Ryzen 5 1400 (less cache, lower base clock). The 1500X includes a really good cooler, suitable for a decent OC. The 1070 will just make it smoother, which helps with not getting dizzy while playing. And I believe a RX580 8GB is on par with or slightly better than a 1060 6GB, if he can't afford a 1070.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
He's got around $1,500 total to spend. Right now as configured we're at about $1,2xx. I don't know anything about AMD Processors, so I'll do a little research but I think we'll be sticking with Intel. Quick look - the 1500x processor is only $10 less than this 7500. The 1070 will add about $150. And even the RX580 will add some cost as well. Something I'll check out though.
Thanks for a quick response and recommendation.
Switch to a single 2TB HDD instead of two 1TB HDDs. No reason to get 4 NF-F12s for that system, they're not good case fans. The 750W power supply is overkill.
Saving some money on those things should leave room for a larger SSD.
It would also be a good idea to consider getting an Oculus Rift instead of the HTC Vive. Better value for money at this point.
The two 1TB drives is so I can do a mirror. He's not storing much of anything other than the VR games on here so 1TB is enough, just provides redundancy. The NF-F12s are being used two in the front where it needs to pass through the drive cages first and one will be used for the radiator. So I suppose I can get rid of one. The PSU and Case come with a package deal, and for the price I'm okay with the overkill. As for the SSD it's only going to be a boot drive so I didn't see a point in a larger one. Although a 240GB V300 is only about $40 more.
More to consider! Thank you.
Not sure where did you see that he has around 1500USD to spend, if so he could do much better :D
PCPartPicker part list: https://pcpartpicker.com/list/6YWk3F
Price breakdown by merchant: https://pcpartpicker.com/list/6YWk3F/by_merchant/
CPU: Intel - Core i7-7700 3.6GHz Quad-Core Processor  ($294.99 @ SuperBiiz)
Motherboard: ASRock - Fatal1ty B250 Gaming K4 ATX LGA1151 Motherboard  ($102.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($114.88 @ OutletPC)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($107.88 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1070 8GB Video Card  ($394.99 @ Newegg)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($52.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.89 @ OutletPC)
Total: $1223.49
Generated by PCPartPicker 2017-05-25 18:36 EDT-0400
Total: $1223.49
I greatly appreciate the time it took you to come up with this (no matter how fast or not), but the price only looks good until you factor in OS, Fans, Optical Drive, and CPU Cooler cost. Then add $250 to that. Price needs to be TOTAL. So yes, I suppose I could go different with the fans and cooler. And I will look into some of these and compare as possible swap outs.
Much appreciated!
Get Ryzen 5 CPU. i5 only has 4 cores 4 threads which means not future proof enough since games will begin to use more and more cores. Ryzen CPUs will provide stabler framerates in games which is more important than average framerates.
Get Ryzen 5 1400 or 1600
Edit: SSD quite bad, this will help:
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Thanks for the input! I'll for sure be checking out that SSD list.
EDIT: Ended up going with the SK Hynix SL308 over the Kingston. Thanks again!
