Hello
In the last few days I checked out many different components and I think I finally decided what I should get. The build will be used for some gaming and light content creation as well as doing school stuff. I already planned the switch from a laptop to a desktop for a while so I already have a monitor, a keyboard and a wired internet connection. :) I can probably order the missing parts next week.
These are the parts for the build:
CPU: Ryzen 5 1600 - about 216€ (This CPU is amazing)
CPU Cooler: Stock cooler
GPU: RX 570 - about 200€ (I still don't know which model, mabye I even end up buying a RX 580 4Gb)
RAM: 2x8GB Crucial Ballistix Sport LT white - about 44€ for each stick (I already bought this memory since it was on sale)
Motherboard: ASRock AB350 Pro 4 - about 93€ (Choosing a motherboard was very difficult for me, I'm still open for other suggestions)
SSD: I already own a Samsung 750 EVO
HDD: WD blue 1TB - about 45€
Case: Fractal Design Define S - about 70€ (I already bought this case since it was on sale)
PSU: Seasonic Prime Gold 650W - about 105€ (I want a quality PSU, don't tell me that a cheaper one would work as well)
Fan: be quiet! Pure Wings 2 140mm PWM - about 10€ (I wanted to have some additional cooling so I orderd this fan toghether with the case)
Total price would be about 827€ (not including the SSD I'm already using in my laptop and the operating system I have to buy).
Personally I think this build will look decent as well since cable management in the Define S is easy and I will probably add a Cryorig H7 in the future. This cooler will the black and white color scheme I have because of the ASRock board, the white RAM, the Define S and maybe even the graphics card if I pick up the MSI RX 570 armor. And I will upgrade to 16GB soon.
Update: I bought a second stick of RAM because it was still on sale.
Update 2: I bought an ASUS Prime X370-Pro because it was on sale.
Update 3: I have bought everything except the GPU. I'll use an old GPU I've borrowed from a friend. Hope it works. xD I'll probably buy a GTX 1060 later. Not having a good GPU is not a big problem since I will be able to edit the video we have filmed some month ago. Another future upgrade will be a better CPU cooer even though the stock cooler AMD provides with their R5 1600 is already a decent cooler.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/784533-feedback-for-next-build/
Might wanna do 16GB RAM for the content creation bit, so if you haven't ordered the RAM get 1 8GB or 2 8GB
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887760
1. Any cheap b350 mobo would do
2. See if Seagate Barracuda is cheaper,  equally good
3. The quality you are getting fron a Prime unit is not something you would able to notice unless you spend on an expensive PSU testing unit or at very least open up PSU and look what's inside it. Just get a Corsair CX450M instead for cheaper or Seasonic M12II if you want full modular cables, I think @Energycore would agree too since he is here
4. I would try to spend a bit even for a 580 4gb, else see how much a 480 costs, it should still be bit faster
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887766
Well I don't want to steer people away from buying amazing PSUs :P
But you're right that an M12II or a CXM or a B3 would do the job just as well.
Computer Specs:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887773
Forgot to mention this, I'll add it to my post. I want to upgrade to 16GB soon. But for now I will just use the 8GBs I've already bought.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887778
well if with the money he saved from psu to upgrade 570 to a 580 then i think it's worth it imo, besides they all have a 5year warranty and by that time his pc could have been obsolete maybe
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887794
Yeah I already have some knowledge aboug PSUs as well I I often recommend the CXM (gray label) and the Seasonic S12 II. I already planned some builds for family and friends and 2 of those feature Seasonic M12 II Evo PSUs. But I appreciate the longer life span I expect from the Prime Gold and the 80+ Gold rating is nice to have as well.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887800
But if your computer is obsolete and you upgrade it you can carry over the PSU ;)
Computer Specs:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887812
Maybe the CPU or GPU is obsolete in 5 years but I can still use the PSU for my next builds. But I understand your point. The thing is that I don't have a strict budget. I want to spend about 800€. Maybe I'll get a RX 580.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887819
Thats my play. And if I need a new PSU after upgrading because there are new connectors or something like that I will just use it together with my R5 1600 as a server.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9887833
Why would you downgrade that PSU? If I were downgrading I might get This instead
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9888860
I don't want to get a lower quality PSU. The PSU isn't a variable in my build.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9890631
Don't be pessimist to your chosen PSU, just keep to that choice and YOU will be thankful to your feelings
My head on 2019 :
https://linustechtips.com/topic/784533-feedback-for-next-build/#findComment-9890641
