Scratch on Acrylic Side Panel
RyeIII
My 2 year old nephew scratched the side panel of my Phanteks Enthoo Evolv ITX, can I still remove it or what is the best way to conceal it?
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
Depends how deep it is. If it's very shallow you may be able to buff it out. If you can feel it when you run your finger across it, you can't really get rid of it.
If it is just shallow scratches, try using a car wax thingy with microfiber cloth, that's how I treat my scratches :D
heat from a blow torch will change the appearance but you will never get the scratch out. ( not too hot or close to melt ) ( wave back and forth across the area ).
