Same FPS on ultra and low with 1070?
Solved by trentklein,
2 hours ago, Shreyas1 said:see if vsync is on
14 hours ago, chexor said:I got a friend (he has 6600k on 4.5Ghz and 1070 g1 gaming) he's newbe with pc's, i built him pc, but he's learning, onace he said to me that GTA V is not working like it should be, then he installed fraps and his fps was 30 on 1080p when i want to his house and checked, he maxed out resolution scaling (+250%) so maybe you have some problem with software..
15 hours ago, MrJarhead said:not a problem mate.
Alright figured it out!! I done a stupid haha long story short when I installed it, I bumped a ram stick and that opened one of the tabs making a ram stick pop out and the gpu backplate was resting on the tab so the gpu was not fully seated as well. Not sure how it even worked as well as it did.
