I need help with the fan connector
Teetech
Guys am working on my nzxt H440 case and when I turn it one the fans won't spin how do I connect it
1 minute ago, Oshino Shinobu said:
Is the molex power connector for the hub connected?
Where do I connect it? To the pSu?
To the PSU, yes
Do I have to connect another wire to the CPU-opt?
No, you should just need to connect the molex power connector from the hub into the PSU then all the fans you want into the hub. The CPU fan headers should be used for CPU coolers really.
I believe the hub supports a PWM signal through the white 4 pin connector. If the case comes with a cable that's 4 pin to 4 pin, plug it into one of the 4 pin fan headers on your motherboard and into the white 4 pin connector on the controller. I think that's what the 4 pin connector on it is for.
