While I Play Grand Theft Auto IV, I get Like 56 FPS No More & While The Traffic Is high, Like Many Cars Blow Up Around Me The FPS Go Down To 40 FPS Even More Down..Everything Is On High Settings & I really Don't Know Why Is That Any Help..
Resolution - 1280 X 1024 (60 HZ)
Specifications -
Processor - Intel core I7 3770k 3.50 GHz
Graphic Card - EVGA GTX 670 (2 GB)
Motherboard - Asus Maximus V Gene
Ram -Corsair vengeance (8 GB)
https://linustechtips.com/topic/7839-low-fps-while-playing/
well Daviidd I have the same problem its just because the game was poorly ported over to the pc i found the best way is to set everything to med but i run a Asus Radeon 7870 Ghz edition.
if you want anymore info if you still have problems just ask me because i got mine to run really smooth.
https://linustechtips.com/topic/7839-low-fps-while-playing/#findComment-87683
Well It Run Smooth But Everyone Know When FPS Drop Down To 40 Etc Is Badd,So I Decide To Ask If there Is any solution
https://linustechtips.com/topic/7839-low-fps-while-playing/#findComment-87770
well im right there with you i tried finding fixes that just like cleaned up the games coding so it ran smoother. If you figure out how to fix it plz let me know because i would love to make mine run so much better.
https://linustechtips.com/topic/7839-low-fps-while-playing/#findComment-87778
it was playable for me with a HD5830 at 2560x1600 all settings highest except maybe AA and view distance
is there a known problem with nvidia cards?
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/7839-low-fps-while-playing/#findComment-87912
Nope The Nvidia - EVGA GTX 670 Run So Smooth And Clear, But I was Wonder Why My FPS Is Getting Low, But I can Say This Card Is Like More Than I Expected!!, First I wanted The EVGA GTEX 680 But Many People Told That There Is No Much Different Between Those 2 Card, So I decide To Go With EVGA GTX 670, I Also Could OverClock It But I Decide Not To ATM
https://linustechtips.com/topic/7839-low-fps-while-playing/#findComment-88504
Hmm, strange one, my mate showed me it running on his rig with a GTX570 and some crazy mod that made it look absolutely stunning and it was running beautiful. I'll ask him if he had to do anything to get it running sweet and let you know.
Okay Dude, Thanks!
https://linustechtips.com/topic/7839-low-fps-while-playing/#findComment-88518
