I am having a problem picking a GPU for my needs that fits in my budget . I trying to make a computer for streaming and recording game play i need it to run "Minecraft" and "Kingdom come Deliverance".
I am unfamiliar with the difference between the GPUs in the market
like how much of a difference in quality is there between 10XX and 9XX or the AMD side of the GPU market or which GPU would best fit my needs
The build I have so far is
MB-  Msi B350 Artic tomohawk  120.00
CPU- Ryzen5 1600                    220.00
GPU-
PSU- corsair 450w                       45.00
Ram- 1x Fury 16GB 2600          150.00
SSD- Kingston 2.5  120G             53.00
HDD- WD blue 7200 1TB             50.00
case- DIYPC VII-W-15                  50.00
         LEDlight White Dual
Total                                            $727.00 of a $900-$1000 budget
Any input would be greatly appreciated
https://linustechtips.com/topic/783832-having-problems-with-picking-a-gpu/
A 1050ti or a 1060 3GB would work for that. Or an AMD Rx 460/470.
I5 6600K @ 4.6 Gigahertz
Cryorig H7
EVGA GTX 1070 FTW @ 2 Gigahertz
16 Gigabytes of Corsair Vengence
ASUS Sabertooth Z170 S
Crucial 525 Gigabyte SSD
Hitachi 1 Terabyte Harddrive
NZXT Hue+
NZXT H440
Corsair Rmx 650 Watt Power Supply
GPU-
         LEDlight White Dual
Total                                            727.00 of a 900-1000 budget
USD?
RX 480 if you can fit it in your budget.
otherwise, an RX 470, or a used GTX 970.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
1 minute ago, etiienne said:
You'd probably want to look into getting a 1050ti with that budget, but as "DA OG FISH" said a 1060 3GB would work too.
 RX 470 > 1060 3GB because of VRAM
Laptop:
Why are you ignoring the RX 500 lineup? :P
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
It's the same as the 400 series and a sometimes forget it exists lol.
but yes, anything I've said about a 480 or 470 applies to the 580 and 570
Laptop:
GPU-
         LEDlight White Dual
PCPartPicker part list: https://pcpartpicker.com/list/RZ9dPs
Price breakdown by merchant: https://pcpartpicker.com/list/RZ9dPs/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($217.89 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler  ($19.99 @ Amazon)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($77.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($109.99 @ Newegg)
Storage: PNY - CS1111 240GB 2.5" Solid State Drive  ($79.99 @ Amazon)
Storage: Seagate - Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ Amazon)
Video Card: MSI - Radeon RX 580 8GB ARMOR OC Video Card  ($229.99 @ SuperBiiz)
Case: Rosewill - GRAM ATX Mid Tower Case  ($24.49 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($37.99 @ Newegg)
Total: $842.30
Generated by PCPartPicker 2017-05-23 20:01 EDT-0400
