Hey so this is what i will be building next month: https://uk.pcpartpicker.com/list/XYMF9W is there anything i should change? (budget is under £850)
Also i have a few questions: 1) what do i do if i connect it all up and nothing happens? as in what do i do if on of the parts is broken? how will i know which one it is?
                                             2) this will be my first proper pc (i use a laptop that gives me 30 fps in cs) what games would you reccomend me to try out? any genre!
Edited by DocBrown
wrong link (im special)
https://linustechtips.com/topic/783721-first-build-help-also-questions/
Just now, ONOTech said:
Not bad.
My suggestions:
  1. You have some left over cash. Pick up an SSD!
  2. I recommend an R5 1500X or 1400 over the i5. It's about the same price, overclockable, and gives you similar performance.
  3. If the 580 is the same price as the 480, then go for that over the 580.
The Freesync monitor is a nice choice.
what do you mean by your third point? as in get a 580?
Don't get i5,  get Ryzen 5
16GB RAM is recommended
Add a SSD if possible
Which is cheaper, RX 480/580 8GB or GTX 1060 6GB?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  (£169.99 @ Amazon UK)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£28.05 @ Amazon UK)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard  (£68.52 @ Amazon UK)
Memory: Crucial - 16GB (2 x 8GB) DDR4-2133 Memory  (£83.99 @ Amazon UK)
Storage: Kingston - SSDNow UV400 240GB 2.5" Solid State Drive  (£74.00 @ Amazon UK)
Storage: Seagate - 1TB 3.5" 7200RPM Internal Hard Drive  (£32.24 @ Amazon UK)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  (£199.99 @ Amazon UK)
Case: Game Max - FALCON WHITE RGB ATX Mid Tower Case  (£49.95 @ Amazon UK)
Power Supply: SeaSonic - ECO 430W 80+ Bronze Certified ATX Power Supply  (£43.79 @ Amazon UK)
Monitor: LG - 24MP48HQ-P 23.8" 1920x1080 60Hz Monitor  (£92.99 @ Amazon UK)
Mouse: SteelSeries - Rival 300 Wired Optical Mouse  (Purchased For £0.00)
Headphones: Kingston - HyperX Cloud Stinger  Headset  (Purchased For £0.00)
Speakers: Logitech - Z200 0W 2ch Speakers  (Purchased For £0.00)
Total: £843.51
Generated by PCPartPicker 2017-05-24 04:34 BST+0100
