Greetings,
I've come here with a simple yet annoying dilemma. I've built a new system recently and everything is all well and good except for one glaringly annoying thing. Whenever I alt tab out of a game my keyboard will disconnect and reconnect. This happens in both full screen and windowed full screen. This happens with any game I have. Both Steam games and non Steam games. Also notice this when first booting up the PC and shutting down it will do this. I've done some research but couldn't find anything specific to my problem except for this article: http://www.techsupportalert.com/content/how-fix-annoying-windows-usb-problem.htm which explained it may be the power saving options. I went and changed the settings thinking I had found my issue and... nope still doing it :( I'm hoping someone here may be able to help me solve this issue. Thanks!
The Keyboard I'm using is the Vortex Pok3r and I'll also note I have a Razer Naga 2014 plugged in and a Zowie FK1+. The Naga is partially detected as a second keyboard but that's never caused me any issues before on my previous systems. Also both my keyboard and mice are plugged into the USB 2 ports on the motherboard instead of the USB 3. I've tried both didn't make a difference in this issue
If it helps computer specs are:
Ryzen 1600X
Asus ROG Crosshair VI Hero
Radeon 280X
16GB G.Skill Flare X @ 3200mhz
Samsung 960 EVO M.2
Windows 10 Enterprise 64-bit (Yes I actually do have an enterprise SKU)
https://linustechtips.com/topic/783376-weird-issue-when-alt-tabbing/
