Need Graphics Card Help
Go to solution Solved by Megah3rtz,
3 minutes ago, jond1122 said:
Hello,
I am doing a PC Build and have the final parts picked out, except for one problem. The graphics card I wanted an ASUS Radeon RX 470 has been discontinued. What it another one I can get for around the same price point?
is the RX 570 available?
Hello,
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873423
Heya, I see you're interested in the ASUS RX 470, well that's been discontinued (obviously), so maybe you'd be interested in the ASUS RX 570, they have virtually the same performance, so it should be a good substitute. Here are some links if you wanted one.
ASUS SITE
AMAZON CANADA
AMAZON USA
AMAZON EUROPE
NEWEGG USA
NEWEGG CANADA
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873444
4 minutes ago, jond1122 said:
Yes, its a bit more expensive though. That's fine. If you need to know I will be pairing it with a Ryzen 5 1400
Whats the rest of your PC that you are planning.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873455
How much did the radeon 470 cost before it was discontinued?
My Rig
 Peripherals
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873458
ASUS SITE
AMAZON CANADA
AMAZON USA
AMAZON EUROPE
NEWEGG USA
NEWEGG CANADA
Thanks!
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873470
Im blind sorrry found it.
My Rig
 Peripherals
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873475
Whats the max card length your case supports, do you care about what color it is, do you need specifically an amd gpu for something like free sync.
My Rig
 Peripherals
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873573
30 minutes ago, jond1122 said:
About $165
an RX 570 should only be about 10-20$ more, I'd wait for one to go onsale personally. even the low end models as long as they have 2 fans are okay.
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873642
you can get a 1060 3g which is worse than a 570, but better than a 470. Its the same price as a 470
My Rig
 Peripherals
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873671
My Rig
 Peripherals
https://linustechtips.com/topic/783319-need-graphics-card-help/#findComment-9873677
