I've had my PC for around 5 months now, and every month or so I open it up and remove the dust. The problem is I think it's quite a lot of dust build up for one month. My house is always dusty, even if every week its cleaned :/. I was hoping if anyone has any good tips/products to help with the dust issue? I use the the S340 with and the case fans it came with, and the two filters that came with it.
Thank you!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/783293-dust-problem/
Thank you!
Holy crap you have the same problem as me. My house doesn't look dusty but every time I clean it, it is dusty again within a few days, I have the S340
https://linustechtips.com/topic/783293-dust-problem/#findComment-9873064
Honestly, your best bet is to get new filters. It doesn;t look like the S340 comes with replaceable filters, just the metal "filters" built into the case. If that is true you can mod the case to fit something that resembles the mesh they use on screen doors. I might take a stroll down to my local PC shop and see what they have. Otherwise, get a new case or a air compressor.
https://linustechtips.com/topic/783293-dust-problem/#findComment-9873083
8 minutes ago, Tyleredbowers said:
get a filter
Thank you!
Here's my Pentium D rig, I want it to look as ghetto as possible. It is still very good though, I have a fan cooling the PCI and PCI-E cards with the hard drives outside my case for good temps.
https://linustechtips.com/topic/783293-dust-problem/#findComment-9873093
You did a very good job with that
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/783293-dust-problem/#findComment-9873104
1 hour ago, Daniel Z. said:
This is my real rig, the cable management is crap cause I just installed a new Wifi card. I have some ghetto cable sleeves, will get real ones soon
Ooh nice
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/783293-dust-problem/#findComment-9873707
