Customize CPU Fans
Solved by dantayy,
1: Yes, but your motherboard will usually give an error if no fan is connected to the CPU Fan header, and the fan control might be a little off as the motherboard controls the CPU Fan header based on the CPU Temperature, plugging it into a case fan might result in the fan speed being controlled by the motherboard temperature sensors instead of the CPU temperature
2: There are RGB LED headers on your motherboard, take a look at your manual, do not connect the RGB light strips to any fan headers
