try reseating the gpu or cpu and then if that doesn't work then unplug all power connectors 24-pin, cpu power, gpu power etc.
CPU - Intel i5-6600K 4.7Ghz
MOBO - ASUS Z170 Pro Gaming
GPU - GALAX GTX 1080 EX OC SNPR
RAM - Crucial Ballistix Sport DDR4 8GB
SSD - Samsung 850 Evo 250GB
HDD - Seagate Barracuda 4TB
CPU Cooler - Cooler Master Hyper 212 Evo
CASE - Corsair Obsidian 450D
PSU - EVGA Supernova 750 G2
3 minutes ago, willforthebest said:
I had some issues with my psu (fans went on for 1 second and then shut off) but now they are all fixed. Now for some reason when i turn on my pc everything does what it normally does but it doesnt pick up my pc on my monitor and does not start up! PLEASE HELP!
Clear CMOS if that doesnt work then it is PSU issue
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
PSU works fine as all the parts are getting power, its just that the output is f'd.
Do you have any USB devices with lights in it? Do they still turn on/get a signal from the motherboard?
My mobo died a two months ago and didnt give any output to any of the devices, GPU wouldnt give a signal either.
Started Folding@Home on 02-05-2015
I will try that now
