1 minute ago, Tcarr9442 said:
So I am planning my first custom waterloop build, and I was wondering which I should go with.  A Pump Res Combo or get them separate?  Also what should I get with about 150$ for pump and res?
It's mainly up to you as the builder, there is a slight benefit of have a separate pump res unit for vibration isolation leading to noise. Personally my favorite is to have a pump res combo especially since it helps saves space if you have a smaller case.
As for a unit EKWB makes a nice one:
https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
you get a choice for pumps, primarily ddc or d5, the d5 as I understand it is a little quieter and cooler, but has less pressure than the ddc. Most recommendations are to get the d5 because the pressure shouldn't be an issue in a typical custom loop
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
