Okay so  i installed my new motherboard (GA-78LMT-USB3) and the front panel audio doesn't work. You see, i believe it is because the motherboard default is HD and my case is AC97 and i found no option to change in the bios. I tried to install another driver but the one 8.1 had already installed seemed to be such. If any of you know how to change it in the bios please tell me.
https://linustechtips.com/topic/782864-front-panel-audio-not-working/
