Help with disk management
Go to solution Solved by kachel94,
Right click on the black unallocated part of "Disk 1" and select "new simple volume" follow the wizard any you should be good!
Hello, I was wondering if someone could help me with my disk management. Right now I have a 500gb ssd with my os on it and a 2tb hdd for storage. The hdd doesn't show up in in the device list with my C drive but it does in disk management. What can I do to get the hdd working properly?
Thanks
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/782572-help-with-disk-management/
Click on it and format it
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
as pelark said, you have no drive letters assigned since you havent formated any of the partitions, try assigning a drive letter first to the preexisting ones if you have any data there presumably, then if it's not important, delete the unnessecary partitions.
You two are awesome thank you it worked!
The Impossibox
WhisperingKnickers
x58 Fan Page
