I am not sure if I should convert my Existing Basic Disk to a Dynamic due to these various reasons:
1) Will my SAMSUNG 850 EVO SSD have any Performance Improvements when I Convert to Dynamic
2) What other Benefits will I get by converting to Dynamic
3) Are there any Downsides to Dynamic Disks?
1) No
2) Partitions are dynamic, i.e they can be all over the place
3) Maybe not
Don't bother wasting time converting it because if you need to convert it back you will have to reformat the disk
https://msdn.microsoft.com/en-us/library/windows/desktop/aa363785(v=vs.85).aspx
https://technet.microsoft.com/en-us/library/cc737048.aspx
Thanks deXxterlab97,
After Conversion to a Dynamic Disk, I wasn't able to TRIM my SSD natively using Windows Optimize Drives (Optimisation Not Available).
To resolve this, I had to reinstall windows and reformat the entire disk during the install process.
You usually can't boot or install Windows on a Dynamic Disk.
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
