Well been messing with overclocking for about two weeks now on and off to reset defaults and I think I finally fixed it here are photos from a 20 minute test I did twice. As well as the benchmark test which takes as long as it needs to my score was 1438. Is that good?
Anyone know memory OC too? I'm looking in to that now as well how to set it up correctly as well.
If my CPU is good to go at 5.0GHz
As well I didn't touch anything but cpu multiplier and vcore and offset.
How about this AVX offset I left it default which on my board (Z170 classified k) is 3.
Vdroop fine on default?
I'm new to overclocking & my first build. Just want to make sure I'm doing this Overclocking the right way.
One question opening certain programs jumps my temp to 4(x)c sometimes 5(x)c from idle 32c. Is that normal? I use this PC for recording gameplay and editing videos and rendering which is the most reason I want 5.0Ghz so It'll be quicker than ever before. My old PC used to take 14 hours (that's right and true) to render an hour video.
Photos of stress test today at 5.0GHz Vcore on auto with a offset of +75 temps never hitting over 70c.
Yesterday at 4.8GHz hitting around 78c-83c with a lower Vcore (I thought this was quite weird)
Tried again 5.0 at 1.335V though when testing 1.363 & 1.381 it said was the fluctuates of vcore for the temps for prime95 v26.6 test was 79c-80c. I say cause it passed the 640k test then was trying to do its 8k test temps went above 90c.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/781955-am-i-overclocking-wrong/
