So after moving back this switch (in the picture below) and losing it in my case, I got it back after shaking my case back and forth, with help so it never hit the ground really hard or anything like that.
now I'm getting really weird CPU voltages, like over 1.4V and I know that's dangerous for an i7-6700K so it would be helpful to know what's going on. I have nothing running in the background and haven't tested anything in game yet, but I can play rainbow six or CSGO on Friday, if you want to see my system specs just go down to that drop down menu
and one more thing, its turbo boosting to 4.2 GHZ for no reason whatsoever
Thanks
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/781584-weird-cpu-voltage/
so long as its not over around 90c, youll be fine
have you tried capping the voltage?
you could also try removing the jumpers completely and see if that helps, it try shorting 1-2 with a fork or something just to be 100% sure that the jumper is not the problem
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/781584-weird-cpu-voltage/#findComment-9854302
Fully remove the jumper, wouldn't that totally mess up the CPU voltage
Quote
PCPartPicker URL
https://linustechtips.com/topic/781584-weird-cpu-voltage/#findComment-9858301
