Help with a $550 build
Go to solution Solved by Cyracus,
PCPartPicker part list: https://pcpartpicker.com/list/jmBvQV
Price breakdown by merchant: https://pcpartpicker.com/list/jmBvQV/by_merchant/
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($59.48 @ OutletPC)
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard  ($62.99 @ SuperBiiz)
Memory: G.Skill - NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($54.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.33 @ OutletPC)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card  ($220.99 @ SuperBiiz)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($44.89 @ Newegg)
Total: $491.67
Generated by PCPartPicker 2017-05-18 14:01 EDT-0400
Idk about wireless network cards so left you enough for that and a budget keyboard and mouse. You said you had case and monitor, but this should handle most games
Hi.
My 8 years old laptop died today, i loved it even if it was a piece of junk (i was forced to play WoT at 14 fps, disgusting). Rest in peace.
I want a Tower PC to play games like League of Legends, World of Tanks and Civ6. Also, if its possible that it can play modern games like Dark Souls 3 atleast like a ps4 i would be happy.
Also, im from Colombia so i need that the parts can be shipped internationally, i will get a case locally since shipping one is kinda expensive.
In summary:
- A pc for "basic" gaming.
- All the regular parts for a Pc except the Windows licence (i already have one) and the case.
- A net card (or net adapter, sorry i cant find a better way to translate the name) since i cannot connect with a cable.
- The peripherals are apart from my budget, except the monitor.
If im asking for impossible things please feel free to correct me, i can stretch my budget $30 or $40 if it would increase worthly the performance.
https://linustechtips.com/topic/781429-help-with-a-550-build/
7 minutes ago, Sandstormcarrier said:
Hi.
I want a pc to play games like League of Legends, World of Tanks and Civ6. Also, if its possible that it can play modern games like Dark Souls 3 atleast like a ps4 i would be happy.
In summary:
so...around 550 us? it won't be a gaming beast but it can be done. And if I read correctly a tower pc not a laptop, yeah. I'll post a build link in a few moments
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/781429-help-with-a-550-build/#findComment-9852044
Total: $491.67
desktop
HTPC
https://linustechtips.com/topic/781429-help-with-a-550-build/#findComment-9852129
1 minute ago, valdyrgramr said:
They're not in the US.  They're in Colombia.
I got that, if they need it tweaked down they can get a cheaper graphics card, but at least now they can get some idea of what they can get
desktop
HTPC
https://linustechtips.com/topic/781429-help-with-a-550-build/#findComment-9852168
 Thanks for your help. Im going to do some research to see what can i do with your info.
https://linustechtips.com/topic/781429-help-with-a-550-build/#findComment-9852180
If you need to shave off $50 then a radeon 570, if you need to go $100 lower the 1050ti should get you there, either will still provide a good gaming experience, but naturally you get what you pay for. happy I could help
desktop
HTPC
https://linustechtips.com/topic/781429-help-with-a-550-build/#findComment-9852206
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($59.99 @ B&H)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  ($63.44 @ OutletPC)
Memory: Kingston - FURY 8GB (1 x 8GB) DDR4-2400 Memory  ($67.99 @ SuperBiiz)
Storage: Western Digital - BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB SSC GAMING ACX 3.0 Video Card  ($154.89 @ OutletPC)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($38.85 @ OutletPC)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $505.14
Generated by PCPartPicker 2017-05-20 03:48 EDT-0400
https://linustechtips.com/topic/781429-help-with-a-550-build/#findComment-9860598
