So, My liquid cooling had nearly zero noise, ofc I was normally using a headset and or had some type of back ground noise. Recently I noticed this sound happening
near the end of the video you hear it really well. I was just wonding is that normal or is this breaking. Some people said I need to replace it just want to make sure first.
Also just 5 minutes ago, My pc randomly started to freeze and get really slow. I rebooted and now it's working fine, not sure if the cpu caused that or?
https://linustechtips.com/topic/781316-help-with-liquid-cooling-please/
Is it the rattling sound? If it is the bearing in the pump or fan could be going. My old CPU fan made that noise and it had a bad bearing.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
