Help with Streaming PC
By
Guest
in New Builds and Planning
Solved by Cyracus,
well, since you seem to be planning to do a gaming rig with ryzen I'd say build that and see if your current rig handles streaming well enough. If not it should at least manage until you can get a new streaming system running, or depending on the ryzen cpu you get try streaming from your gaming rig
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
derekchan ·
Posted in New Builds and Planning6 -
5
4
6
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
