Just now, NovaTastic said:
And also wont i need to remive the 5.25 bays?
Not sure what you mean but you would take the top 1 or 2 5 1/4' bays with one of these
https://www.alphacool.com/shop/pumpen/pumpen-mit-agb/20558/alphacool-eisfach-single-laing-dc-lt-dual-5-25-bay-station-inkl.-2x-alphacool-dc-lt-2400
And the big res would go beneath/ to the side
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/779913-will-it-fit/#findComment-9833202
Thanks for the help!
https://linustechtips.com/topic/779913-will-it-fit/#findComment-9833329
