I was testing my stability of Ryzen build today, and I got temps like that after running AIDA64 for 30min.
CPU temp didn't go above 72°C so that should be fine. But I'm more worried about those temps that are 85°C ... during gaming those don't get any higher than 70°C even after hours of playing, so I guess it's not a big deal while gaming. But when rendering, those temps could very well get to those 85 or 90°C. Does anyone know if those temps are safe and till what temperature those temps are safe?
Running R7 1700 at 3,825GHz 1,35V on B350M moratr motherboard.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/779726-motherboard-temps/
They seem safe... AFAIK, Ryzen will automatically shutdown when temps exceed 85C
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831347
For CPU temps probably yeah. But I'm still 15°C away from it, and while gaming it doesn't even get to 60°C so I should be more than fine about that.
Still those motherboard temps are bothering me a bit since they would reach 90°C or higher if I was pushing my CPU further. Are those VRM temps on motherboard near CPU maybe?
WD My Cloud 4TB
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831441
Is this your motherboard?
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831509
Yap it is.
WD My Cloud 4TB
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831560
Just now, Simon771 said:
Yap it is.
The VRM heatsink isn't too big, so this is probably the reason why the VRMs got quite hot under load...
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831570
Any idea what's the max safe temp for those VRMs?
WD My Cloud 4TB
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831607
Unfortunately, no...
https://linustechtips.com/topic/779726-motherboard-temps/#findComment-9831630
