Hey,
I've decided to replace my old CM Elite 430 Case and CM GX750W PSU, mostly because the PSU is pretty loud and the case has pretty bad cable management options. I've chosen Corsair RM750x 750W and FD DEFINE C BLACK WINDOW. Can you guys give me your opition about these two items or suggest me something in that price range or cheaper? I'll be using these two with the components in my signature.
i7 7700k | MSI Z720 SLI PLUS | Asus ENGTX 470 | 2x16 Corsair Vengeance LPX 3000Mhz | Samsung Evo 850 120GB & WD Black 640GB | FD Define C | Corsair RM650x
https://linustechtips.com/topic/779681-case-and-psu-replacement/
Both are great.
The RM750x is a very quiet PSU, where the fan doesn't even spin up under low loads. It's also modular and has cables with capacitors to reduce ripple. The FD Define c is also wonderful, it's got a lot of cable management space and is very compact for a ATX case. It's also sound isolated, if that was a concern.
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9830852
1 minute ago, Ethocreeper said:
the rmi variant cost only 7 more
Only difference as far as I know is the corsair link feature, so I guess that is up to op
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9830880
Just now, Ethocreeper said:
but its cool
It's up to OP to see if it actually adds any value to him
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9830893
If the RM750i is only $7 more than the RM750x, the benefit from going with the RMi is Corsair Link (monitoring capability), switchable single rail (convenience) / multi-rail (added protection) mode, and a higher quality FDB fan.
Between the two, I would say getting the RMi is well worth the money if it's only a $7 difference; however, this discussion may be irrelevant depending on your location, as regional pricing / availability may be different.
Also, your system can be powered on a quality 550w. Do you have plans to SLI in the future? If not, you could save some money by going with the RM550x, RM650i (doesn't come in 550w), EVGA Supernova 550 G2 / P2, Bitfenix Whisper 550M, etc.
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9830988
@Ethocreeper, I just checked and the stores near me don't offer the RMi, just the RMx.
@quan289, I'm not planning on SLI, but I'll probably swap that ancient GTX 470 with something more up to date :) The only reason I chose the 750W was that the 650W model was just 10$ cheaper and I thought that the higher wattage will ensure lower usage % so it will keep the fan not spinning, but that's just my logic and I'm not 100% sure that PSU works that way :D
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9831280
The fan will spin dependent on heat and not necessary system load. I'd save a few bucks and buy the 650W personally.
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9831540
RM750x was out of stock so I followed your advice and got the 650W one and FD Define C. I'm happy with the results - noise level decreased significantly and coil whine disappeared. Cable management can't even be compared to my old case :)
Thank you all!
https://linustechtips.com/topic/779681-case-and-psu-replacement/#findComment-9846626
