1 minute ago, lacoral said:
My EVGA 1080 Hybrid just started doing this after a few months and it will not output anything to the screen. (It was working great.)
Maybe RMA it?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/778945-help-with-my-1080/#findComment-9823105
Just now, lacoral said:
I was hoping someone would have an idea but I can send it back if I have to.
RMA is probably your only hope.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/778945-help-with-my-1080/#findComment-9823116
2 minutes ago, lacoral said:
looks like its gonna be a few weeks of old reliable.
Yeah I sounds like the cooler isn't coming in contact with the die as well
https://linustechtips.com/topic/778945-help-with-my-1080/#findComment-9823139
May I question as to whether or not you still have of a warranty/guarantee for such dedicated GPU? You should contact EVGA, as that card can't be more than a few months old now, and EVGA are pretty good for customer support I would say.
Meanwhile, make sure it is seated correctly in it's PCI slot, and check over your PSU with making sure your GPU power connectors are in correctly. May I ask what those loud clicks were? If they weren't you, then that is nearly 100% you not having put a power cable in correctly like the CPU ones & so forth.
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/778945-help-with-my-1080/#findComment-9823189
I am positive it is seated correctly and the connectors are properly connected. The clicking was the PSU switch.
https://linustechtips.com/topic/778945-help-with-my-1080/#findComment-9823199
