8 minutes ago, George_Bud said:
Ok, so, I have this ram ( http://www.crucial.com/usa/en/ct16g4rfd4213 ) and a Asus B350M-A Prime.
Is it compatible ? On the box says that ECC Ram is ok with the motherboard and on the guide it says that is ok with ECC Ram.
But what do you think ?
trust what they are saying
https://linustechtips.com/topic/778652-help-i-need-help/#findComment-9820029
1 hour ago, George_Bud said:
It was a good deal
ECC RAM is meant for workstations and servers.  The premium they charge for this type of RAM is not worth it for everyday machines.  Also, the checks that ECC RAM does takes time and i'm not sure if they run in parellel, so you could see them performing worse in your machine than non ECC RAM.  I would look into that more, since i'm not quite sure.
https://linustechtips.com/topic/778652-help-i-need-help/#findComment-9820181
