Hi,
I've recently been experiencing some lag issues on my PC. I have switched the case of my PC in the last 3 days but that is the only change that has been made to it in the memorable past. I'm running a fairly old rig consisting of a GTX650, an i5-4570 and 4GB of ddr3 RAM. The lag itself has been occurring on all applications and desktop.
If anyone can help me out please let me know.
Thanks,
joshoq23
https://linustechtips.com/topic/778651-lag-issues/
3 minutes ago, joshoq23 said:
snip
Well my basic checklist:
Does the disk or CPU hit 100% in normal use? What are the temps of the GPU / CPU?
If you have a motherboard brand software, uninstall it (ASUS AI suite, etc)
Check hard drive smart status (Crystal disk info)
Check hard drive speed (Crystal Disk mark)
Try to look for new drivers / updated BIOS
Drastic, but:
Reinstall windows
https://linustechtips.com/topic/778651-lag-issues/#findComment-9820001
10 minutes ago, joshoq23 said:
Hi,
Thanks,
joshoq23
Drastic, but:
Reinstall windows
Make sure that you have installed ALL drivers and made sure that you have the newest version of windows by 'press Windows Key + R, type “winver” into the Run dialog, and press Enter' and make sure that it is version/build 1703 or higher, it gave me MAJOR improvements. If your build/version is not that, then use this to update, which is silly of microsoft not releasing it properly, but here you go: https://www.microsoft.com/en-us/software-download/windows10
for any more problems or just to say thanks, reply:D
https://linustechtips.com/topic/778651-lag-issues/#findComment-9820022
Drastic, but:
Reinstall windows
On top of this: for the new case, check if the PSU and system fans are clean - this could be thermal throttling from the move to the new case messing with the PSU
idk
https://linustechtips.com/topic/778651-lag-issues/#findComment-9820023
