Is everything wired correctly? Does the monitor work? Does your monitor change what it displays at all (even for a second)?
Specs?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/778509-help-no-video/#findComment-9818562
1 minute ago, Drjack6 said:
Ive checked the wiring. Nothing is wrong (as long as im not missing something)
Tried 2 different monitors. And both vga and dvi ports
What are your specs? Are there any error codes/beep codes on the motherboard?
PSU Tier List | CoC
https://linustechtips.com/topic/778509-help-no-video/#findComment-9818574
Just now, Drjack6 said:
I just noticed this. When i press the power buttoin, the computer turns on for a few seconds then shuts off. Then turns itself back on again in a second., Whats that? Never had that happen before
  1. What are your specs?
  2. Make sure everything is fully inserted/connected.
  3. Remove the CMOS battery (the thing that looks like a quarter) and then put it back in.
  4. If it still doesn't show any video, then unplug any drives, any PCIE cards, all but one RAM stick, and USB/other peripherals.
PSU Tier List | CoC
https://linustechtips.com/topic/778509-help-no-video/#findComment-9818607
2 minutes ago, Drjack6 said:
asus b150m dvs r2.0
pentium g4560
crucial 8gb ddr4-2133 (1 stick)
mushkin ssd
Your motherboard probably doesn't have a Kaby Lake compatible bios. So it won't work, you'll have to find a Skylake CPU or someone with a Skylake CPU to update the bios.
PSU Tier List | CoC
https://linustechtips.com/topic/778509-help-no-video/#findComment-9818631
ive used plenty of h and b series from asrock and asus with kaby lakes. never a problem before. I doubt thats it.
But knowing my luck, ill call asrock and thatll be the problem
150/170 boards will work with Kaby Lake if they have a compatible bios. KL compatible bios launched in November 2016~, so at this point most 150/170 boards will have a Kaby Lake compatible bios, however it's not a guarantee.
PSU Tier List | CoC
https://linustechtips.com/topic/778509-help-no-video/#findComment-9818637
is there a way to update it with no post?
Not without a Skylake CPU.
PSU Tier List | CoC
https://linustechtips.com/topic/778509-help-no-video/#findComment-9818643
