so the @ symbol is next to the shift key well its moved to the number 2 key (i think apple use that layout) but it changed for no reason at all how do i change it back helpppp this is so annoying
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/778366-corsair-strafe-layout-issue/
4 minutes ago, Haeking said:
You should have the key lifter you can just re arrange them
ok so on the number 2 key if i shift and hit it i should get " but i get the @ symbol instead
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
Just now, Haeking said:
on an american based keyboard set 2 gives @ where are you from
uk it was fine and now for no reason at all today it changed
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
It should be the keyboard language to be exact its set to american, instead of uk
ye but theres no uk option the fuck
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
what version of windows is this
10
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
3 minutes ago, Haeking said:
Type in region and language options to search, there should be a part that says country and region with the united states, click on that and then go to uk
nope nothing
in corsair link the only option is english (american) the fuck
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
2 minutes ago, Haeking said:
found it i must of hit windows key and space love u
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
No problem best of luck
thanks i did the first bit already but step 8 with the windows key and space bar thats what i must of hit at some point
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
