Hey guys.
I have a littlle problem this morning, when i woke up and turned my pc on then it were alot louder than it used to be, i figured that was just once so i restarted but the same thing happened. Then i looked at my temperature meter on my motherboard and it said it was on 70-80, when it's usally on 50-60. But if i let it stay a little while on the desktop without doing anything then it goes down, but if i open a program like Chrome then it goes up around the 70-80 again, can somone tell me what the problem is or have any idea about it?
Thanks in advance
- Tjampen
(sorry if this is the wrong topic, didn't know where to put anyway)
https://linustechtips.com/topic/778195-temp-going-up/
1 minute ago, Tjampen said:
Hey guys.
I have a littlle problem this morning, when i woke up and turned my pc on then it were alot louder than it used to be, i figured that was just once so i restarted but the same thing happened. Then i looked at my temperature meter on my motherboard and it set it was on 70-80, when it's usally on 50-60. But if i let it stay a little while on the desktop without doing anything then it goes down, but if i open a program like Chrome then it goes up around the 70-80 again, can somone tell me what the problem is or have any idea about it?
Thanks in advance
- Tjampen
Are you overclocked? Air or liquid cooled?
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814665
Just now, Tjampen said:
I haven't overclocked anything and my CPU is liquid, rest is air
Just wonder if something got messed up very unlikely though, have you tried resetting your bios?
If that doesn't work I would try re mounting your cooler of putting new thermal paste on.
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814675
Remind me again how i reset my bios?
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814684
No i don't think so every thing looks normal in task manager
Have you tried to turn off the system and unplug the PSU, wait 15 seconds and then boot up once again.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814689
5 minutes ago, Tjampen said:
So i am back, unplugged the psu waited 15 seconds, didn't work, resetted my bios, didn't work. And now my temp meter on my motherboard is going even more crazy with 80-90 :o and still constantly loud
Do you still have warranty on your motherboard?
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814736
I am certain that i have, but i could be mistaking
Really stupid question from me, your cooler is on liquid cooling right? Is your pump working?
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814751
Its the temperature on his motherboard, not CPU.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9814756
Those could be just sensors malfunctioned. Its not that uncommon, though this is first time I've heard the broken midway. Not from the box. Mobo components can take temps up to 110C... so...
@Tjampen, could you post screenshot of the readings? And have you tried if whole thing crashes during some stress testing?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/778195-temp-going-up/#findComment-9820025
