I didn't know where to post this, but it is audio, so I posted here.
I am trying to redo my car's entire audio system. It only has stock stuff in it as of right now. It is a 2002 Volkswagen Jetta, if that matters. I am just trying to figure out if all of this stuff will work together, and well in this car. And I can't decide which head unit, or speaker set I should get. I kinda wanna go with the Pioneer speakers, and find a nice Pioneer head unit, and have an entire Pioneer system. What do you think?
Link
"If you gon be bout it, be bout it bout it" ~ Gavin 'itsjusta6' Simon
I play games - Look at my profile for specs
I love memes. I make bad memes, but I like dank memes, who doesn't?
I am good at editing videos and pictures, feel free to message me if you would like some work done.
Thanks!
Kole Overby
Owner At:
Chaos Network
DanTheNali Videography
Employee At:
Neighborhood Mechanic
Heinen's Powersports
https://linustechtips.com/topic/778135-car-audio-system-tips/
Just now, themctipers said:
what audio sources will you need/have?
Bluetooth with my phone. I need to have BT calling thru this. And an AUX cord for if someone other than me wants to play something. The occasional CD or USB stick maybe. And of course, just the radio sometimes
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/778135-car-audio-system-tips/#findComment-9814036
have devices for this already in the car? (cd player built in, maybe a modern reciever?)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/778135-car-audio-system-tips/#findComment-9814037
The car's stock radio has a CD and tape player built in, as well as radio.
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/778135-car-audio-system-tips/#findComment-9814041
my recommendation would just be to get one of those tape to aux converters, and then you can just play whatever you want from your phone.
linus sex tips
https://linustechtips.com/topic/778135-car-audio-system-tips/#findComment-9814050
