multi monitor card
Solved by Bluejay0,
For 1440p, 2GB won't be enough.
Inches don't matter for VRAM size (heheheheheheheh, inches)
760 4GB is NOT worth it. the 256-bit bus is a major problem since it's a bottleneck. It's found on the 760 and 770.
For multi-monitor configs, go for AMD.
I recommend going for the 280X
Featured Topics
1
8
munem939 ·
Posted in Power Supplies1 -
6
1
6g2 ·
Posted in Troubleshooting1 -
NickKz ·
Posted in Programs, Apps and Websites6 -
