Hello Everyone
Finished my First PC Build.
I`am wondering if the Prime 95 Temps are too high? (Yesterday New Arctic Silver 5 applied and pc is running maybe for 3 Hours now in total)
System Specs:
Intel Core i7 7700K BOX (LGA 1151, 4.20GHz, Unlocked)
EVGA SuperNOVA P2 (750W)
ASUS MAXIMUS IX FORMULA (LGA 1151, Intel Z270, ATX)
Samsung 960 EVO (250GB, M.2 2280)
Microsoft Windows 10 Home (Vollversion, OEM, DE, 64-bit)
ASUS DRW-24D5MT
EVGA CLC 280
Corsair Obsidian 750D Airflow Edition (Big Tower)
Asus GeForce GTX 1080 Ti Strix
Corsair Vengeance RGB (4x, 8GB, DDR4-3000, DIMM 288)
https://linustechtips.com/topic/777409-prime-95-temps/
Temps are fine, what overclock/voltage are you running at? I usually aim for 90ºc or so in P95, which generally leads to 75ºc under more realistic loads.
EDIT: 80ºc~ at only 4.2ghz? ouch.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805282
Just now, djdwosk97 said:
Your temps are fine. I usually aim for 90ºc or so in P95, which generally leads to 75ºc under more realistic loads.
My Man Dj again :)
Slowly but surely i have to start to pay u my friend :D Thank you for all ur answers.
Btw: I did run Prime only for about 15mins and i think i heard arctic silver 5 needs a long time until it reaches the full potential/best temps so is it possible that the Themps could go down in the near future?
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805291
no idea
PSU Tier List | CoC
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805293
Well those temp are under 90°C so it should be fine.
I'm sure your temps won't get that high while doing normal daily tasks like gaming and maybe some editing.
I guess max temp will be around 70-75°C during long hours of doing those normal tasks.
But yeah ... i7 7700k is running hot. If you want to do any serious OC, you should delid it.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805316
Thank you very much and i guess i wont overlock i dont wanna break my first pc build :D
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805319
Yeah delidding is a bit risky. It's kinda safe if you are using delidding tools, but still .... only KINDA safe xD
WD My Cloud 4TB
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805324
You can try to lower the voltages and overclock a bit, and you also have some more thermal headroom to play with if you want.
PSU Tier List | CoC
https://linustechtips.com/topic/777409-prime-95-temps/#findComment-9805333
