Hi All,
I'm planning a new build for my GF (Dec 2017) I know that's a way off but cases are unlikely to fundamentally change much and I'll be getting the hardware later. She would like pink of course... However I think an entirely pink build is just going to be... intense :P So I was considering a white build with pink accents (parts of the chassis, pink cables and pink fluid when I do a loop in there but they may be a future upgrade).
Luckily being an engineer I do have access to the company's paint shop so I can power coat parts any colour I want (as long as the parts can be disassembled from the body and reattached after painting). What cases do you think this would be easily to do this with?
The only requirements are:
- Must suit full ATX form factor motherboard
- Must be mid tower class (has to fit on her desk)
- Ideally mainly white already however I can also coat parts white.
- Must be able to install a custom loop without modding
Off the top of my head I was thinking S340 elite with the cable management bar in pink?
All other ideas are welcome.
Many Thanks,
Tom
https://linustechtips.com/topic/777379-two-tone-case-mod/
1 hour ago, W-L said:
In terms of watercooling and modding the Mastercase would be an excellent candidate for this, the S340 is good but lacks some of the mounting space for large rads.
Which version?
https://linustechtips.com/topic/777379-two-tone-case-mod/#findComment-9807343
2 minutes ago, tom_w141 said:
Which version?
Which ever one suits your build needs, they are all modular so taking it apart and putting it all back together are just a matter of bolting pieces, where you wouldn't need to drill out rivets to take apart most other cases.
https://linustechtips.com/topic/777379-two-tone-case-mod/#findComment-9807353
