Hey guys, so recently I've had some real issues staying connected on my Killer 1525. It can keep a connection when on Wireless but I get really bad ping in game (not sure why), and whenever I try connect to Ethernet the connection completely drops every 5 minutes for a few seconds so I get kicked from games all the time and makes it impossible to game both wireless and wired. I've tried downloading the most recent drivers to no avail, I've also tried looking through all the Killer software but I couldn't really find anything in that? Any suggestions would be greatly appreciated this is getting really frustrating. It's not all the time by the way, I was able to game for 3 or so hours last night, then I get up this morning and it is impossible to stay connected long enough to even find a game online.
EDIT: I have gigabit internet, here is my Speed test: http://www.speedtest.net/result/6279387749
Thanks in advance for any help guys!
https://linustechtips.com/topic/776850-killer-wireless-1525-connection-issues/
Machine specs?
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
Just now, Flanelman said:
GTX 970m
i7 4770HQ
16gb ram
1tb 7200RPM
Killer 1525 n/a/ac wireless network adapter
What about your Ethernet adapter? Unless its a Killer and it runs on the same drivers, it should not be doing the same thing
How do I find my Ethernet adapter? under my network adapters in control panel there is a "TAP-windows adapter v9"? other than that it's just the killer one and loads of different WAN ports and a RealTek PCIe GBE family controller.
This one. Try downloading the original drivers from your laptop manufacturer for both your 1525 and GBE. Then uninstall both and install again.
