Best thermal paste for a delid... After a delid, you don't need thermal paste there? If you mount the CPU cooler without a lid, there is only a single layer of thermal paste required.
Also, what CPU are you going to delid? Because some are soldered... Some crazy german dude managed to delid a soldered Ryzen R7 1800+, and mount his CPU cooler straight to the chip. He got maybe 1-2 degrees better temps. So there is that.
https://linustechtips.com/topic/776769-best-thermal-paste/#findComment-9797076
