2 minutes ago, azemuno said:
Am I able to cut the PWM cables and the molex power cables to resolder and reduce the length? Could there be any problems?
Yes you can do that as long as you match the cables back together and don't cross any wires.
https://linustechtips.com/topic/776324-cutting-d5-pump-cables/#findComment-9791872
1 minute ago, wzrd said:
Yes, I do it all the time to sleeve them. You shouldn't have problems if you are used to doing it.
Awesome thanks guys. I am used to doing it I just wasn't sure if PWM held any extra precautions.
https://linustechtips.com/topic/776324-cutting-d5-pump-cables/#findComment-9791883
