Hello,
Here the deal , currently i have been running an amd phenom 2 x4 955 be and a gts 450 for many years now. I have finally gotten the money to upgrade my pc. The thing is that the new parts i wanna buy need to last for some years as it will be impossible for me to upgrade soon.
I use my pc for gaming , games like bf4 ,crysis 3 etc , and sometimes encoding videos
I will be buying the parts on amazon.co.uk.
My budget is 800 pound for 3 components : the cpu , the board and the gpu
I am thinking of getting the
i7 4770k
Nvidia GTX 780
 for board either an asus maximus vi hero  or an asrock extreme 4 ???
what are your views on these three parts
i have a silverstone RL02 case
Power supply: silverstone gold evolution 750 watt
8 gb of corsair 1600mhz ram
Your help would greatly be appreciated.
https://linustechtips.com/topic/77626-need-advice-on-a-build/
Soo, what's the question ?
CPU: FX-8350, GPU: xfx radeon r9 290, RAM: corsair venegance 8gb, STORAGE; seagate barracuda 1TB hdd, SSDnow kingston 120gb, CPU COOLER: CM hyper 212 , CASE: fractal design XL, PSU: corsair CS 650w 80+ gold MOBO: Gigabyte GA-990FXA-UD3
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065326
The CPU is good, but about the GPU if you wasn't it to last 3years i would recommend either waiting for the 790 (if it ever Will be released) or something like the TITAN. And about the mobos i would go for the Asus one ;)
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065430
Why titan? the 780Ti is faster and cheaper?
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065444
yes but speed isn't everything, the TITAN has more gb and cuda cores
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065476
Dont get an ROG board. You won't see any kind of performance boost or longevity increase. Unless you need the PCIe lanes lanes don't buy it (and even then there are better alternatives).
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065477
Ignore what he said.
If you are mostly into gaming you should get an i5 4670k. No difference in gaming performance, and still good for some video encoding. Also, the 780 at 1080p is gonna last you a very long time. If it's within your budget, you could grab the 780 ti instead. It's also faster than the TITAN and much cheaper.
EDIT: Get the hero.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065484
but these new games are coming optimized for 8 cores etc , i thought the i7 would have an advantage , also a 780 gtx is max i can buy ,
about the board which any better recommendation ?
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065510
No the TITAN has 2688 cuda cores, the 780TI has all 2880 cuda cores.
The 6g ram will not be helpful for his uses, he is just single 1080p gaming.
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065512
sorry about the commenst earlier, my retarded friend had a go while i were in the shower..
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065589
I understand, my brother is the same way. I assume that means you recommend the 780Ti?
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065662
yes ;)
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065703
Or the 290x
For his budget, the 780Ti makes more sense.
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065726
Oh didn't see there was a budget :/
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065735
800 British pounds for cpu/gpu/mobo
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065769
Pounds ey.. I don't have brain capasity for calculating that..
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1065792
The 780 Ti is a bad value. The Titan is as well for gaming.
Are you limited to amazon?
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1070302
Yes it is, but it is a good performer.
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1071546
The 780 is also a good performer and has a better value.
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1071724
True. If he needs the performance then 780Ti if not go for the 780 to save money.
https://linustechtips.com/topic/77626-need-advice-on-a-build/#findComment-1072170
